    Nov 2001
    USA
    A week ago I did a complete format and clean install of the OS.
    I've reinstalled TMPGEnc Plus v2.5, but so far its crashed every
    attempt to encode. These are errors within the .exe file.
    I remember when this happened before, I changed some settings
    under the VFAPI plug-in tab. For the life of me, I can't remember
    what they were. Are there definitive settings under this tab?
    On the same note, is there a guide for all the settings in TMPGEnc
    as well as VirturalDub? I've never gone thru these programs with
    the idea of optimizing the settings.
    TIA
    Why doesn't this work?
    Mar 2002
    United States of America
    You might have bad frames in your source file.
  3. Try raising your DirectShow MultiMedia File Reader to 1 or 2
    Mar 2002
    If bad frames are the problem, here's a guide for taking them out:
    https://www.videohelp.com/forum/userguides/142555.php
    Hope That Helps!!! :P
    Nov 2001
    USA
    I'll definitely give that a try. If I recall correctly, I changed more than
    just this setting. What settings should I use for the other ones?
    Thanks again!
    Turk
