Please help
I have a TDK 4X dvd Burner with DVD +r
I have a AverDVD EZMaker caputure card.
I use a NeoDVD 4.1 plus.
My problem are
1. Click on the NeoDVd Icon
2. the taskbar NeoDVD open
3. show on taskbar tool are Capture, Create and copy
3. I click on the capture
4. there are error said " Can't read DMA access"
5. I click OK then the error said " can't finf ASPI library"
6. I click ok then it allows me to capture from vcr to harddisk with mpeg2
7. I click Create to make mpeg2 to format DVD; but the error show #4 and #5. But it allows me to make formating on DVD
8. I click on Copy to burn the DVD. then Neodvd can't find the TDK DVD burn driver. I try to use Nero Express. I can't burn it
Anyone can help me how do convert mpeg2 to DVD format; so i can burn it i can watch DVD player.
Thank you
didnt know of a tdk 4x dvd burner -- didnt it come with some burner software ?
Not sure what the problem is, but maybe trying to install updated aspi drivers or even uninstalling and reinstalling aspi 4.60.
Check google and search for ASPIchk tool and check what aspi layers you have. Also if you have Intel Application Accelerator, try uninstalling that too.
Hope this helps.
how to convert dvd to other format
By steelmaster in forum Video ConversionReplies: 2Last Post: 27th Apr 2012, 13:26 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 09:23 -
Recent recorded hom evideos to DVD now in Mpeg2 format... what to do?
By tehfreeman in forum Video ConversionReplies: 2Last Post: 19th Dec 2008, 12:07 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
