Running Win XP and after downloading various films have found many that
are unable to be deleted just says file currently in use..I read sometime
ago there was something that could be done within the registry files which
allows you to delete these files is this still possible and could someone explain how Cheers in advance![]()
What is happening is : You click on it (to delete it) and windows goes out and tries to d/l the codec so you can see it in the preview window. Installing the codec will stop this.
Simple, but a royal pain in the ass. You can delete the folder they are in. You can not highlight them and delete from a command line (del filename from the same folder they are in). You can turn off the preview option by changing your desktop layout to 'Classic'. You can disable you internet connection ( remove IP ), etc etc etc.
If your good you can highlight multiple files and hit delete, since it can't do multiple previews, usually you can delete all but one.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thankyou both very much have tried the solution from the past post and
have solved all the problems..thankyou once again..
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 23:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 21:32 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 05:03 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24
