I've downloaded QTReader for TMPGEnc, but after encoding my .mpg (SVCD) file is not audible - no sound... I'm trying to convert MARTIX: RELOADED trailers (QT6). What is wrong or what I can change... HELP!
=SWooP=
Kill one - you are murderer.
Kill many - you are conqueror!
Kill 'em all - you are GOD!!! -
More than likely the audio is encoded (a lot of quicktime movies have encoded audio for some reason). You might have to generate a seperate wav file with total recorder (see the guides to left under convert).
I had a similar problem with the Animatrix. The first one encoded fine, the 2nd one had no audio. -
quick question.. when you played the QT MOV file thru the QT player, what happened?? did you get audio? if you didnt then you have your answer right there, as the needed audio codec is not installed. (btw, it is possible to have a true, normal QT6 installation and not have _all_ the audio codecs that are in use by everyone creating QT MOVies. yes, I know that sounds obvious to most, but it's non-intuitive to new users).
if you did hear audio then it gets a bit more complicated.. it could be that the QTReader for TMpgEnc just cant handle that format (though I've converted a lot of MOVs and never had that problem). also, go back re-check to make sure you didn't have the TMpgEnc options set incorrectly.
-s. -
Got it! I've registered QuickTime and extracted audio track to .wav file. Opened .mov file in TMPGEnc and audio took from .wav file. Encoded .mpg file is O.K.!
Thanx to all participating...
-=SWooP=-Kill one - you are murderer.
MOV problem
By mowashear in forum Video ConversionReplies: 0Last Post: 23rd Jun 2011, 10:10 -
Problem Converting AVI (DV) to MOV (DV)
By Casho in forum Video ConversionReplies: 3Last Post: 15th Feb 2011, 05:27 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 00:21 -
Quicktime/MOV files in TmpGenc
By buddycat in forum Video ConversionReplies: 2Last Post: 20th Mar 2009, 21:54 -
framesize problem with Mov to DVD
By Burny in forum ffmpegX general discussionReplies: 5Last Post: 24th Mar 2008, 05:57
