Can someone please tell me, if my DRU500AX is set to region 2 can I still burn NTSC discs. Also is there a way to make this drive region free.
Dobbs
As far as I know, region code is completely different to video format (NTSC, PAL...) So yes, you can burn NTSC files. The region code is set so you can only play DVDs with the same region code, or no region code at all. The files that you burn have no region code, unless you instruct you DVD authoring & burning program to set a code, but as far as I know, standard DVD+-R media doesn't accept CSS encoding (someone correct me if I'm wrong
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
Sony S580 region locking
By cheekiestgrin in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Oct 2011, 19:46 -
Change Sony BDP- S350 From Region (1) to Region (4) can it be done?
By MOTHGIRL in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Sep 2008, 21:58 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 04:34 -
Sony DVD region
By tasher98 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 3rd Jan 2008, 12:17
