when I want to copy one of my dvd-r discs, if I try to do a direct one-to-one copy, by putting the original in my dvd-rom and my blank in my dvd-rw drive, I get a coaster 2-3 times out of 10.
when I rip the disc, then burn a new disc with the ripped files, I never get a coaster (over 350 burns)
obviously, the one-to-one is way faster, more convenient, etc.
is there any advice anybody could give me as to how I can make this problem go away? my computer details can be viewed above.
Andy![]()
Your not trying to copy on the fly are you? Are your dvd-rom and dvd-r drives on the same ide channel as master/slave? Create an image of the disc then burn the image to the new disc. Hope some of that may help, if not maybe list more details on process including software & maybe somebody will spot a flaw somewhere.
I am using on the fly and they are on the same channel. Is that the problem?
my current setup:
IDE1:
Master
VD-ROM
Slave
VD-RW
IDE2:
Master:100GB HD
I'm burning with Nero. My specs are above. -
you mean to the HD right?Originally Posted by Treebeard
that was similar to the second option i listed that i was trying to avoid for reasons of speed, HD space, convenience. -
drewson99,
I know that this topic is for few month ago, however, I am wondering if you got the answer from anywhere else. If you did, I will appreciate it if you share it with me. Thanks.
Problem to write DVDs from LG DVD recorder
By avz10 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 28th Apr 2010, 01:11 -
Help! Cannot rip this DVD - wierd problem...
By Comfy in forum DVD RippingReplies: 2Last Post: 8th Dec 2009, 11:10 -
HP DVD1040I Burning Problem: Won't Recognize or Write to DVD+R DL
By JimBarbasol in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Aug 2008, 10:55 -
Write problem with FH-16AYH burner on Memorex DVD+R DL
By hibbs in forum DVD & Blu-ray WritersReplies: 12Last Post: 4th Jan 2008, 04:30 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 13:58
