Hi , I can't find out what is the problem and why I get white solid square across captured file, that square stand there for a 10 sec, and then dissapear.
The comp. is Atlon MP 1700, 256 DDR, HDD Quantum 30Gb 5400, MB Epox KT 333. I need help please-how to capture without having white square.
PS. It doesnt apear every time.
it calls Macrovision which is used to protect people from copying. If you want to get rid of the white sqare in the middle, try down grade your driver to version 1.08. This would fix the problem you are having.... hope that helps.....
Don't ask me for the driver..... -
Ok, thank you if that is the problem, my friend have the same card and he doesn't have such problem.
I will try your advice.
Thanks again
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 11:32 -
Time Domain Correction (TDC) and Black and White RS-170 video signal
By tpg in forum Capturing and VCRReplies: 0Last Post: 26th Nov 2010, 09:21 -
Does the SpursEngine devices, IE Leadtek's WinFast PxVC1100 work good?
By TBoneit in forum Video ConversionReplies: 3Last Post: 15th Aug 2009, 16:50 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 09:05 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 13:22
