id like to convert my video _ts folder stuff to iso how do i do this?![]()
I believe that dvddecrypter does that as well (I dont think I have ever done that exactly, I always make an ISO from the DVD-R in my dvd drive, but I am sure you could). You can also use nero, just burn it to the image recorder.
DVDdecryter will rip from a dvd to your HD in .iso format. But if the movie has been ripped to your HD as video_ts folder containing .buf, .vob, .ifo files dvddecrypter won't convert it to a .iso file. If you want to convert it to .iso Imgtool will do it then just burn th .iso to dvd using dvddecrypter. I've used Imgtool a few times to do this. Works good. I actually prefer doing this way. I'm don't care to much for burning the video_ts folder to a dvd with Nero for some odd reason. Seems more simplistic using Imgtool and dvddecrypter. If you choose to you can use another burning program like Nero to burn the video_ts folder and the including files to a dvd.
Stay away from Nero if at all possible.
Dload the IMGTools utility at http://www.doom9.org There are two of them, one for making an image file from the VIDEO_TS folder (and the other for burning the IMG file). I personally burn with DVD Decrytpter thou. -
To convert VIDEO_TS folders on a mac to .iso files you can use AquaISO (free download at Sourceforge: http://sourceforge.net/projects/aquaiso ). AquaISO will create an uncompressed image of the folder, one that you can mount, write, or burn. If your VIDEO_TS folder is larger than 4.3 GB then it won't fit on a normal 4.7 GB DVD using AquaISO. However, if all you want is an ISO image then AquaISO will work for you.
MKV To VIDEO_TS / ISO / DVD
By Valentin in forum MacReplies: 1Last Post: 31st Aug 2010, 21:13 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
Cannot create ISO file with this type VIDEO_TS menu, Why ?
By RWANDREWS in forum Authoring (DVD)Replies: 2Last Post: 30th Apr 2008, 13:44 -
Which is best to burn - img, iso or video_ts
By dynamique in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2007, 15:13 -
iso to video_ts
By 69ers in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2007, 18:56
