i´m trying to encode a D2V + WAV files in TMPGEnc, from a FILM movie, files obtained from DVD2AVI), using the FILM TMPGEnc template.
i´m getting a "stream writing error" message after a few seconds from the beginning.
any suggestions?
try using an mp2 stream with your d2vinstead of wav
i use besweet with the gui -
thanks morey, for your suggestion. it seems d2v and wav files sometimes dont´like each other.
your suggestion should work since what i did yesterday was to encode separately the d2v file and the wav file, and it was ok.
later i would join these files with tmpg tools (hope there files synchronization will be ok!).
regards,
Error: "There is no subpic stream for the menu......." What does
By tplowe56 in forum DVD RippingReplies: 4Last Post: 23rd Apr 2010, 12:06 -
corrupted m2ts file - "cannot detect stream type"
By ac1j2 in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2010, 08:51 -
VirtualDub "Access Violation" Crash, Alternative Program?
By Ruro Jiruries in forum EditingReplies: 6Last Post: 29th Jul 2008, 17:16 -
Error "no usable writing device installed"
By saramalik in forum DVD & Blu-ray WritersReplies: 5Last Post: 23rd May 2008, 04:42 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20
