After running the demo I am very very close to purchasing a license fo Disco+... there is just one thing: if the movie is not the first title on the dvd, DiscoPlus does not split it, it always splits the first title, no matter how short or irrelevant.
I tried entering the title number of the dvd in the title window of DiscoPlus both before and after dragging the DVD symbol onto its window, but DiscoPlus still processed the first, useless title on the Disc.
I am a PAL user and experienced this problem on the region 2 discs Bringing Out The Dead and Sleepy Hollow.
Is it a bug, something that will be adressed later, or am I doing something wrong??
Apart from this problem, the app really rocks!!
Results 1 to 10 of 10
These guys work really hard; my advise is buy the license (think of it as a donation, if necessary), and chances are your problem will be worked out anyway...
One big advantage of buying the program is that they then allow direct email feedback and support.
I notice that the new version they just released incorporates one of my suggestions made to them by email (selecting auto-chaptering from the start, so that you can walk away and come back to a completed project with no steps required in the middle)
BTW: I am NTSC, so I can't help you on the substantive problem. -
Okay, I might do that, it's a fair point you make. But I would still like to know if somebody/everybody else faces the same problem I described! Or is it, for example, just a PAL thing? DID somebody successfully split a DVD where the movie was NOT the first title??
Hi.Originally Posted by the future
As Mike said, talk to us, we're listening. You have in fact id'd a bug...and quite an illusive one.
It will be fixed withing the hour, and a new version of the software released.
Check here or our site: VT won't let us post an update this soon, so it will be a couple of days before it shows up there.
-K -
That's great to hear! As it's the only problem I had, I will buy the new version!! Thanks a lot for looking into this so fast!
no problem
Its seems to still be assing out on some dvds, but man, some dvds are *really* poorly authored.
Gonna test it some more then get it out, most likely by 3/12/03 PM GMT -5.
Right now, some...new code we are working on (Project "We'll See") is eating into my time
-K -
Oh, that's fine by me... I'm VERY interested in project "we'll see" as well!
Kai, is the disco+ update delayed? I thought you said in another thread it was finished.
The update is there! And Disco+ 1.0.2 managed to split the difficult dvds I mentioned in my first post (where the movie is not the first title) perfectly! Great work, Kai!
Also it works with disc images now! Create a folder in DVD Backup, drag into Toast, create image, mount image, drag into D+. My issues (Quicksilver dual running Jag 10.2) are mainly to do with non critical things like incorrect time displays, loss of FF control, inconsistant chaptering and missing VOB's in fast mode. Those of you still on the fence I think it's time to send Kia and co their $40 fee so they can continue to tweak this thing, This is a great time saver as you don't have to deal with m2v, ac3 files and the audio synch issues that arise when you do so.
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 3Last Post: 25th Jun 2012, 16:59 -
OT - any DJ here can help to ID these Gym/disco MP3?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 20th Nov 2010, 23:42 -
Is this a bug of ConvertxtoDVD?
By jackwolf in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 10:13 -
AutoMKV Bug .........
By RVD2720 in forum Video ConversionReplies: 11Last Post: 14th Mar 2009, 00:26 -
Possible Bug?
By CurtisMinBC in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 25th Jul 2007, 03:55
