Unless your movie is less than 80 mins, you are going to want to use VBR. Always set your min relatively low, about 300-500. Always set your max around 2500kbits (2778 - audio bitrate.) From there I'd say most people use an avg between 1800kbits and 2300kbits. Just use a bitrate calcualtor to determine the avg to use and shoot for between 50-55 mins per disk. Very smooth movies you could fit up to 60 or even 65 mins.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
Entering Video Bitrate Makes Preset Switch To SVCD
By akulier in forum ffmpegX general discussionReplies: 7Last Post: 26th Feb 2008, 05:12 -
By akulier in forum ffmpegX general discussionReplies: 1Last Post: 21st Feb 2008, 04:31
