Was wondering if I could compress a mpeg file to fit it in a cd_rom
Everything is compressible - {except fluids - good thing too or hydraulic jacks wouldn't work
Ask yourself what are you prepared to sacrifice - Quality or the cost of an extra CD .
Reincoding the mpeg in a lower bitrate is perhaps the easiest was to achieve the results you need - ... 1 CD
FYI - because your file is already compressed it HAS lost data from the original - compressing again will result in more loss. If possible obtain the original and just rip/encode at a lower bitrate.
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
VOB into one(!) mpeg2 file
By mitchellgoosen in forum ffmpegX general discussionReplies: 2Last Post: 13th May 2009, 09:19 -
Problematic mpeg2 file
By Caple in forum Video ConversionReplies: 3Last Post: 4th May 2009, 19:03 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 06:49
