Hi 2 all....
I am curentlly using Canopus Procoder at highest quality (2 pass vbr, 10bit) for my dv video to convert them to mpeg for DVD-r
I want to try CCE 2.5 cause i heard great things about it.
Please someone tell me what settings should i use for converting dv avi pal to mpeg2 file (for dvd-r) , my videos are always:
-- PAL DV (type 2)
-- 1 HOUR OF VIDEO (so i'm using the HIGHEST BITRATE)
Please someone give me detail settings for BEST PICTURE QUALITY
Thank you in advance and please excuse my poor eblgish![]()
Results 1 to 12 of 12
If you were using a newer version I could. The oldest I have is 2.64, so some of these settings may or may not be in your version
Quantization Matrices: Set this to Standard, or MPEG-Standard
Select ZigZag scanning Order if your source is progressive (non-interlaced)
Intra DC Block Precision ( 10 )
Set your quantization slider to 5 or less (5 is a good setting)
Use Multipass VBR (I would suggest a minimum of 3 passes)
Use a high 'Average' setting (at least 6000). Also, make sure you 'clean' your input video before you try to encode it. Use a temporal smoother, or a good 2-D Cleaner (they are available for both VirtualDub, and AVISynth).
Set your MAX bitrate to 9800Kb/s
Set your MIN to 0, or 300Impossible to see the future is. The Dark Side clouds everything... -
First of all THANK YOU for your reply....
Originally Posted by DJRumpy
Thank you so much and i'll try these settings tonight -
By 'clean', I mean run your AVI through a filter. You can filter them with a temporal smoother, or a 2-D cleaner, or a spatial cleaner. They can remove 'noise' from your source file, although a pure digital source won't suffer from these affects as much as an analog source (like VHS). From your post, it sounds like these are pure digital, so you won't benefit from them as much. It depends on the quality of your Cam.
Try encoding without them, as see if your satisfied with the result. The good thing about CCE, is it doesn't take days of work to experiment.
Are your captures already in a standard DVD resolution, or will you have to resize?Impossible to see the future is. The Dark Side clouds everything... -
Yes my captures are always in dvd resolution (capture using scenilyzer live).
My camcorder is sony dcr-pc101e and my videos are always PAL (dv avi). -
If the capture quality is good, and their already in DVD resolution, just drag and drop it directly into CCE. Don't worry about filtering.
Thank you for your interest in my question and for your help........
One last thing... Have you ever compared cce with procoder with dv avi conversion to mpg2 (dvd) ?? -
I'm a born again CCE user. Once you see it's speed, and quality, it's an easy sell. I've never used Procoder.
Ok so............
1) I captured my video (using scenalizer)
2) Edited in Sonic Foundry Vegas and rendered as dv avi pal (as i always do)
3) Opened cinemacraft encoder
4) Adjusted all the settings
5) Finished
and now i have a video that has a logo on the top left that says CANOPUS.
WHYYYYYYYYYYYYY????? I tried 2.50 and 2.62 version of cce but no luck.
Any suggestions? -
good luck! -
Thank you for your reply...
I installed a minute ago the PANASONIC dv codec and the logo dissapeared !!!!
I hope that doesn't effect procoder or something else!!!
I hope that everything else will work as they did before....
Thank you both for your help -
Just for the records....the name of the file is hlcdvc.dll and is located under system32.....
Glad you could get it straigh
Best CCE settings for 16x9 progressive video?
By mlong30 in forum Video ConversionReplies: 0Last Post: 18th Apr 2011, 08:22 -
Question re settings in CCE Basic
By eclipse95 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 16:17 -
Vegas Pro 8 user with questions about program (and possible camera settings
By chuchunezbie in forum Newbie / General discussionsReplies: 0Last Post: 27th Apr 2009, 16:32 -
CCE, Procoder, Quenc or HCEnc: which one do you get better results?
By devilcoelhodog in forum Video ConversionReplies: 28Last Post: 31st Jan 2008, 21:41 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 11:56
