OK....
i made a NTSC VCD of a bunch of music videos...however it plays perfect as the original VCD on my computer. I have not burned it to be played on DVD player...just made a backup copy on Data CD...
But for some strange reason when i burned a BACK-UP copy of the VCD MPG onto a Blank Data CD the audio sounds distorted, has a weird poppy crackling noise and stutters for a fraction of a second here and there....
I thought it was the VCD MPG so i moved the VCD MPG off the Data CD back onto my harddrive....and sure enough it played perfect WITHOUT any AUDIO problems/noises....
Could this be due to my CD-ROM not being able to read the VCD MPG good enough??...or maybe its not reading fast enough??
Because like i said on my hardrive its plays PERFECT...i checked several times....
I am concerned that when i do play it on DVD player that that strange noise/noises will happen....or should i assume that it is my CDROM and computer not readin it fast or good enough unless its on my harddrive?
Should i be ok on a DVD player?
ok...i'm not sure if i understand you fully.......did you make this vcd complaint or did you just burn this as a data cd?
don't hang your dirty laundry in public
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 08:00 -
"Insufficient audio data or severe sync problem"
By carsskee in forum ffmpegX general discussionReplies: 2Last Post: 2nd Aug 2009, 17:31 -
Audio is skipping when I play videos that are burned on a Data disc DVD!
By Xenogear900 in forum Software PlayingReplies: 8Last Post: 23rd Mar 2009, 13:12 -
VCD / Audio / Data in only ONE CD!
By demonlhama in forum Authoring (VCD/SVCD)Replies: 9Last Post: 15th May 2008, 09:53 -
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 15:15
