Is there a way I can get Dolby Digital sound or 5.1 on my SVCDs? I currently use Virtual Dub and DVD2SVCD to convert.
Dolby Digital, definitely not. 5.1 channels, probably not. SVCDs support multichannel mpeg audio which supports up to 7.1 channels. Most recievers don't support this and even if yours does, most dvd players can't export it in a SVCD. DVD2SVCD has a 5.1 option, just give it a try and see if it works, but don't hold your breath.
Do a forum search for this as it has come up before. I believe the outcome was that it is not possible. Someone did something with mpeg5.1 audio, but this is only playable with a very small number of DVD players
I couldn't even replay standard stereo sound on my Marantz DV-4200 although it played the SVCD-VBR picture quite happily
I'm not bothered though because I've got a Pioneer DV-350 that plays almost anything
Issues with Dolby Digital Sound (rear audio only for one chapter)
By ehmjay in forum MacReplies: 0Last Post: 20th Oct 2008, 10:55 -
Is Dolby Digital HD/DTS HD on Blue Ray better than Cinema sound?
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 21st Sep 2008, 00:32 -
TMPGEnc DVD Author & Dolby 5.1 Digital Sound - Can it be Done??????
By Sparehead01 in forum EditingReplies: 2Last Post: 28th Dec 2007, 15:53 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
Does Divx contain the Dolby Digital and DTS sound.
By sam9s in forum DVD RippingReplies: 8Last Post: 11th May 2007, 16:37
