  1. I want to capture some VHS tapes and want to keep the high quality but at the same time reduce the file size. I have been playing around with the VCD, Huffyuv, DVD, DivX 4.12, DivX 5.02 codecs and I am pleased with the quality from the Huffyuv and DVD. Unfortunately, the file sizes are getting too big.
    Which video and audio codec should I use to retain the VHS quality? Also does resolution matter as much as the codec (eg. VCD@640X480 vs. Huffyuv@320X240)?
  2. I have had very good results with the PicVideo MJPEG codec. I have an analog camcorder and use V-Dub to capture video from my ATI TV Wonder VE capture card. This codec gives me the best results and gives a smaller file size than does Huffy (almost 1/2 the file size!)
    You can download a trial by following the link below:
    ftp://www.jpg.com/pub/picvideo/PICVIDEO2.exe
    This version will put words on your captured video, but I think it is only about 18 bucks to register, and for me it has been well worth the money.
    Give it a shot and let me know what you think.
  3. You must seperate the capture process from the re-encoding process, Capture the best (usually also the biggest) quality you can and then re-encode. Huffy, DV, MJPEG, are primarily capture codecs. DIVX and MPEG are primarily storage codecs, VCD is a storage format which uses MPEG-1.
    Resolution could be more important than codec. No less than 352x480, I use 720x480 though that is overkill for VHS. Resize and re-encode.
    You could also try Real-Time cap and encode, MPEG-1 or 2 for DVD player, Divx for PC only playback. Resolutions and bitrates at what playtime per disk is your choice.
  4. Originally Posted by DOA
    This depends upon the quality of the video you get from the vhs tapes. So-so quality; I'd capture to 320x240 huffy and convert to VCD. Superb quality; I'd capture to 640x480 huffy and convert to DVD. VCD is a poorer quality than VHS, so I'd stick to the DVD quality if retaining VHS quality was a big factor.
    If you want to reduce file sizes, then think 640x480 divx 5.02. Any time you sacrifice file size, tho, you sacrifice video quality.
    Pobody's Nerfect
