I have a number of VCD's which play fine on my DVD player (Pioneer DV350).
However, i switched my output to RGB from for a much better picture and found that on black scenes, i.e. the start of say STAR WARS, the black screen has lots of dark green squares all over it. Which go away when the screen is playing the film, they only appear when viewing a black screen on RGB output. When viewed on normal setting it's fine, just not quite as sharp.
The VCD was encoded from a DIVX downloaded from the internet.
My question is, can i reencode the mpeg file with different filters etc to correct this problem, or do i need to download the movie again and reencode from the divx, if so, what settings do i need to apply to fix this problem. I use TMPGENC for encoding
Thanx in advance.
Your luminance scale is wrong. It was squashed somewhere during the conversion process, or stretched to PC scale (255). You would need to describe how you went from source, to final output.
Impossible to see the future is. The Dark Side clouds everything... -
I simply opened the divx file in tmpgenc, changed the video and audio bitrates accordingly, then hit start. I did nothing with the advanced settings at all, left them all as standard.
I know there are two settings, Output YUV data as CCIR601 and Soften block noise. Should these make any difference. ? -
The DivX file itself is probably the source of the problem then. You can try darkening the Luminance scale by 15, which will fade those dark green areas to black. You will have to do it in VirtualDub, or AVISynth, as TMPGenc has no filter for that sort of modification. You can use either of the above to modify the AVI, and frameserve it to TMPGenc.
Cheers for the info m8
I've vdub quite a lot for converting 23.976 movies to pal, so i'll have a tinker with the settings and let you know the result.
Green noise using MPCHC to play mt2 files
By Sackspud in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2011, 12:24 -
Removing green fringe from IPod Touch video shot under fluorescent lights.
By Safesurfer in forum RestorationReplies: 4Last Post: 8th Jan 2011, 10:49 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
Green screen glitch with edited mpg files
By vato76 in forum Newbie / General discussionsReplies: 9Last Post: 19th Mar 2010, 11:12 -
Green Initial screen on QT files
By rotuts in forum MacReplies: 4Last Post: 23rd Apr 2008, 19:25
