Anyone had any luck with the 99 minute CDRs? I have a Plextor 12/10/32A and the latest ver of Nero, which both are supposed to burn up to 89.5 minutes on a 99 min. CDR. However, even after setting up the Expert Features in Nero it still won't work. Any ideas folks? - TIA!
Hi there,
Had the same problem Man, the way i got round was to use VCDimage to create a CUE/BIN file and used CDRwin to burn to CD.
BUT your PLEXTOR will only copy out to 89.57 no matter what you do.
You'll need a burner that supports buring out to 99minutes eg-> LG 8080b or a Mitsumi 4804TE and i think that a Hewlard Packard 9100i supports it as well.
Your lucky you have 99minute's cd's. All we can get here in the UK are MIRROR MAX 90 mins.
What a Bummer when i've got a LG 8080b writer and a PLEXTOR 12x1032A.
Anyway hope that helps ya
<font size=-1>[ This Message was edited by: marvel2020 on 2001-09-10 11:39:35 ]</font> -
I have the HP 9100i and I burn all the way to 98min. and 45 seconds no prob, do not use the newest version of nero 5.5.4.0 because overburn be disabled for this burner on this version, I went back to 5.5.3.5 and it works fine, my son's sony only burns to 89min. 59seconds also with nero 5.5.3.5.
2marvel2000
Where in UK could I buy 90mins CDs?
I tried to find them but no success.
TheRookie -
To TheRookie
Here's the only 2 sites i could find that sells them
http://www.cd-rmedia.co.uk
http://www.business-ecommercesoftware.co.uk/business/svpcomm/index.html
There ya go
DVD Writing fails at the last minute
By faithhealer in forum Authoring (DVD)Replies: 4Last Post: 14th Nov 2011, 02:36 -
Creating a 2 minute video
By mgk103 in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 10:26 -
Service to edit 4 minute video
By qjuice in forum EditingReplies: 8Last Post: 5th Sep 2011, 12:57 -
Last Minute TV Advice Needed
By AuroEdge in forum Off topicReplies: 0Last Post: 13th Feb 2010, 19:47 -
Those 99-minute CDs.
By AlecWest in forum ComputerReplies: 14Last Post: 14th Dec 2007, 18:50
