I have an ATI AIW 8500DV and a Sony DRU500A burner. I want to capture a 2 hour and 8 minute concert from VHS onto a Single DVD. I have a multitude of Capture/Conversion/Edit/Burning Software, I just don't know which is best and what settings to use. I captured the concert in DVD Mpeg format and then dragged it into Ulead DVD moviefactory 2.0 and it said the DVD was over the limit, I guess my question is how would I re-encode the Mpeg file to be smaller and fit on one DVD?
NYISLES
"Let's Go Islanders"
Break out the old bitrate calculator. Input one DVD disk, two hours, eight minutes duration. It will tell you what bitrate to use to burn your disk at.
Hello. -
Originally Posted by nyisles
I'm a fan but, boy do they su(k.Don't give in to DVD2ONE, that leads to the dark side. -
First, (In the project settings) make sure the "do not covert compliant mpeg files" box is NOT checked. Go to change mpeg settings - customize - compression. Play with the video data rate (8000 is max) until it shows that your video will fit. Each time you change the rate, select ok - ok and iyou will see the size update at the bottom of the window. Hope this helps.
3.141592653589793238462643383279502884197169399375 105820974944 -
Thanks for the info mecg. I will try that when I get home. I am also reading info in this thread:
https://www.videohelp.com/forum/viewtopic.php?t=147596
NYISLES
"GO ISLANDERS"
Converting VHS to DVD, a few questions.
By Xor2 in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2011, 08:35 -
Help me out with some questions about converting VHS to DVD?
By starheavenheat in forum Newbie / General discussionsReplies: 4Last Post: 6th Apr 2009, 00:22 -
45
By inherindian in forum Newbie / General discussionsReplies: 7Last Post: 4th Mar 2009, 21:26 -
3 questions about VHS > DVD
By Salva Veritate in forum Capturing and VCRReplies: 13Last Post: 26th Jan 2008, 15:05 -
VHS to DVD (basic questions)
By BPH2002 in forum Video ConversionReplies: 5Last Post: 2nd Jan 2008, 10:32
