    Feb 2003
    Netherlands
    I'm creating my own home home dvd's with Ulead DVD Workshop 1.3 and it's a very easy to use program but is has only one problem and that is it doesn't accept dts sound files. I did create my movies with ac3 sound and that is going very well but now I will create them with dts.
    Is there another program that works mostly the same as DVD workshop and will accept dts sound files?
    I tried Sonic Scenarist 2.7 and that program is very difficult and I don't want to spent all my time finding thinks out when it also can be vey easy.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    Sonic Scenarist or maestro are your choices ...
  3. DVDLab from Media Chance is not available yet, but is supposed to be ready for release soon. From my perspective, this looks like a pretty sweet authoring package, and the claim is that it will be able to work with DTS, as well as AC3. See http://www.mediachance.com/dvdlab/index.html
    Regards,
    Eric J
    Feb 2003
    Netherlands
    Thaks for responding, I've seen that page and hope it will come very soon.
  5. DUDE that software looks sweet and for $79.
    Anyways i would suggest maestro, it can do what you want it to and is MUCH easier than scenarist
