Im using ATI AIW radeon PCI, I want to record some tv programs(1:30) and save it in a 700mb cdrom, is it posible?
Trying to capture in the best quality option( Mpeg2). This just to save and later make VCD and or SVCD.
Probably not, unless you set the bitrate to about 1000 kbps. But then you will end with quite poor quality. Better you capture in high quality, cut the file and fit it on more than one CD.
HP DVD Writer 300n SCSI CdRom Device Driver Issue
By link2009 in forum DVD & Blu-ray WritersReplies: 13Last Post: 14th May 2008, 17:50 -
Classic Arcade Games CDROM restarts PC?
By rijir2001 in forum ComputerReplies: 5Last Post: 10th Apr 2008, 00:33 -
directly connect my cdrom/dvdrom to tv
By d_unbeliever in forum ComputerReplies: 2Last Post: 1st Mar 2008, 04:02 -
CDROM that burns commercial media
By Krispy Kritter in forum MediaReplies: 6Last Post: 19th Dec 2007, 10:30 -
System Error. Import ISO from CDROM Drive
By rebelchic in forum Newbie / General discussionsReplies: 13Last Post: 12th Aug 2007, 05:04
