Hello guys.
I’m new to this forum. Just one question.
I just got my AIW 9700 pro and when I’m trying to capture from VCR I have no sound.
I can see and capture video with no problem, but no sound.
I have SB live 5.1 platinum.
I connect my VCR exactly the same way as recommended on ATI site
http://www.ati.com/support/connectors/radeonaiw/connectradeonaiwvideoinput.html
But still have no luck. Do I miss anything? If someone also have AIW 9700 Pro, please help me.
Sorry for my English.
AKM74,
Although you probably would have found this in a search, or in your AIW manual...
I've got a good old trusty ATI AIW and if yours is the same as other models, it uses your sound card (onboard or slot) for capturing the sound. Make sure you have the cable (black one, not long purple one) attached to your AIW and the sound cable (from the AIW multi-cable plug) plugged into the sound-in port of your sound card or on-board sound, whichever you use.
This will have the sound from your AIW go to your sound card (or onboard sound) for capturing. Then when you setup your AIW, you choose which port (sound-in, mic-in...) to get your sound from.
Basically, if you get video and audio when watching TV or whatever, then you should be able to capture both.
Hope it was this easy.....Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
thanx for reply..
attached to AIW input ? or output ? i use purple cable to attach my VCR video and R/L audio to "AIW input". If i will replace it with black cable, how to connect my VCR to it ?
i know i'm sound stupid, but i can't figurout it. -
AKM74,
Nope, seperate cable. Keep the purple one attached if you use that one for input. There should be another cable....
Well, looks like they've gone from the multi-cable to a single audio cable from the 9700 to the sound card. Says so right here in the addendum to the user manual:
http://www.ati.com/support/manualpdf/MulTView.pdf
nice picture for you too...Have a good one,
neomaine
Thanks a lot neomaine, you are very helpful.
After all I have to only connect it internally, if I have ATI 9700 pro.
Strange, they didn’t mention it in manual which come with my card, and there is no “internal” cable in the box (even if I got retail version).
That what was confuses me before.
Thanks again, I will take care of it now.
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 18:41 -
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 06:02 -
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 09:52 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 11:26 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 15:36
