I wanna Capture VHS video to make A VCD to play in my Pioneer DV-434 Standalone DVD player to view on my TV set, im running NTSC, to capture im using A ATI All-In-wonder 64DDR TV Tuner Card (ATI 7500 All-In-Wonder) im capturing directly to VCD format withought re-encoding the software im using is the software that came with my card the ATI MMC (Multimedia Center) Version 7.7 I would like to know what would be the best capture quality settings to capture to VCD from VHS
Here are my options
Frame sequence in the mpeg output stream:
Number of P frames in a Group?
Number of B frames in a Subgroup?
Variable bitrate or Constant bit rate
What is better?
Video bit rate: how many M Bit/Second?
Motion Estimation Quality 0 To 100?
What I wanna know is what is the best settings I should choose to Capture VHS to VCD
Thanx
Sergio
Results 1 to 1 of 1
Done capturing my VHS, what now?
By Akerhage in forum Video ConversionReplies: 31Last Post: 27th Jul 2011, 09:37 -
capturing vhs to hdd
By zulubase in forum Capturing and VCRReplies: 2Last Post: 20th Feb 2010, 18:00 -
capturing from VHS
By halbblah in forum RestorationReplies: 4Last Post: 1st Nov 2009, 17:35 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 10:32 -
VHS Capturing Problem
By sdculp in forum Capturing and VCRReplies: 14Last Post: 12th Feb 2008, 16:08
