If I capture using MPEG1, then convert to RAW AVI with VDUB will I lose video quality?
For some reason I cannot just simply capture in raw avi. I get a message saying "the pins are not connected"
Supposedly its a direct draw problem, but I have never had this issue until I installed a new video card. Its not drivers either... (well it might be)
anyway, if you could help with either question, I will smile.
thanks
PRO
MPEG1 quality is limited to 320x288 (progressive). It most definately sounds like drivers. I suggest looking for correct/new drivers. Also, check your DirectX version, some drivers are not compatable with DirectX 9.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Any time you convert from one format to another there is always a loss in quality.Originally Posted by procrastination"Art is making something out of nothing and selling it." - Frank Zappa
TV scart sockets lose colour
By Roger Jarvis in forum Latest Video NewsReplies: 4Last Post: 14th Feb 2012, 14:44 -
How to reduce filesize and to not lose too much quality?
By xxxThiefxxx in forum Blu-ray RippingReplies: 5Last Post: 9th Aug 2011, 09:48 -
Increase the bitrate---> Lose Quality?
By mark63534 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2010, 14:36 -
Every Time I Crop, I Lose Quality!
By terminalh in forum Video ConversionReplies: 8Last Post: 18th Jan 2009, 14:04 -
Need to lose ~0.03 GB
By koberulz in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2007, 03:43
