I want to convert a DIVX file into a format to burn onto a DVDR and have ran into a few problems.
1. I have 2 DivX files that I need to join together and make a whole film, but Virtualdub doesn't let me add 2/2 onto 1/2 and when I load in 1/2 into virtualdub I get this error:
2. Both files are ripped from a DVD so the quailty is very high. Is there anyway I can put the 2 files together and make 1 whole film? I have looked at the guide here but hasn't worked, in fact half the settings on there look completely different to the ones I had.
So basically all I wanna do is join together 2 DivX files and burn to DVDR.
JLR
Why are the best things things in life cost the most money?
Who stole the rest of my Signature, Own up, it was you, yeah you, thats it I am gonna come over there and .......... -
yours *.avi files have mp3 sound so you should use virtualdub_mp3freeze to avoid the sync problem
you can encode to mpg-2 (dvd) using tmpeg (try kwag's template) and after merge the 2 *.mpg files to 1 final.mpg as a whole movie
2man -
cheers 2man that virtualdub_mp3freeze worked, now you meationed that I should use kwag's template, (which one there are loads)
hi
the kwag's template is for tmpeg encoder
you could frameserve from virtualdub and open the *.VDR in tmpeg
then load the template and encode
you should encode the video alone and then the audio also alone to get more speed during encoding process
sorry the writting
2man
Another problem converting .TS
By iXed in forum DVB / IPTVReplies: 9Last Post: 8th Aug 2010, 13:53 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Problem with converting and playing
By TONYHAMILTON in forum Video ConversionReplies: 2Last Post: 22nd Apr 2008, 13:35 -
problem converting
By aussiemac in forum Video ConversionReplies: 28Last Post: 11th Aug 2007, 16:17 -
Problem with converting in VirtualDub
By Martig in forum Video ConversionReplies: 7Last Post: 19th Jul 2007, 19:12
