My computer currently has a 20gb hard drive which severly limits my ability to do anything with digital video, and so I have ordered a new 40gb hard drive. I would like to add it as a second hard drive so that I don't have to reinstall everything, and so that I have 60gb of total storage instead of 40. I checked things out while installing my DVD burner, and it looks as though I will have to connect the new hard drive to the motherboard using the second connector-thingy on the ribbon that my original hard drive is connected to. If I understand correctly, I will have to set one of my hard drives as a slave so that the computer can tell them apart, but do I have to change any of the settings on the original hard drive? When installing my DVD burner I set it as the slave, and didn't do anything to the DVD drive that I already had in there. Was I correct in doing that, or should I have changed the settings on those, too? Any assistance would be greatly appreciated. Thanx.
I installed a 2nd drive as well recently. No don't do anything to the 1st drive. Install the 2nd as slave.
Although you have installed a second drive it is not like having one hard drive with 60g storage space. Without raid technology what you have are two separate drives. One with a 20g storage space, the other with 40g.
It all depends on the hd. Check the settings {most of the time it's on the top of the drive. } Sometime you have to change the jumpers if you add another hd. If you still have questions go to hd website.
Unable to power on the PC after adding 2nd hard drive
By alegator in forum ComputerReplies: 10Last Post: 3rd Apr 2010, 13:57 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Adding external hard drive
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 14th May 2008, 03:07 -
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2008, 23:05 -
Want some advice about adding a new hard drive
By videocheez in forum ComputerReplies: 19Last Post: 6th Jun 2007, 15:25
