Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Page 1 of 4
1 2 3 ... LastLast
Results 1 to 30 of 91
  1. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I have written a win32 .Net GUI which produces DVD compliant elementry streams or program streams for mpg2. So given a folder with say 2 x 800MB .bin svcd images it will produce either 2 x mpg (48Khz, DVD resolution) or 2 x mpv/mpa ES sets (48Khz, DVD resolution) in about 30-45 mins. These can then be used in your dvd authoring apps of choice.
    The app is just a GUI wrapper for other command line apps like vcdxrip, mpgtx & besweet - all credit goes to those authors. It just means that to get dvd compliant assets from .bin files takes one mouse click!
    Anyway, it works for me but there is still some work to do if it was to be made public. I will do that additional work if there is enough interest... let me know.
  2. this sounds like just the baby i'm looking for m8
    could i test for u please?
    LMK m8 i'm depsperate for this!!!!
    cheers
  3. I would like to test it for you.
    Can you email me a download link?
    Thanks,
    Norm
    nglomski@hotmail.com
  4. I wouldn't mind giving it a test either. PM if you can send me a link!!
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I'll get a release together in the next couple of days (need to iron out a few things).
    Please keep in mind this is a .Net winform so you need the .Net framework....
    Dec 2002
    Sounds good. Kind of like DVD2SVCD in reverse. I know I have a lot of SVCD's I'd like to convert. Definately sounds like a good app.
    Suggestion: Make sure it works with MPG's? As in copied from the SVCD? Maybe sequentially numbered for batch encoding?(file1.mpg, file2.mpg, file3.mpg...etc)
    And now the Nirvanna question: Auto trim. That is clip off X seconds for those SVCD's that repeat at the change of a disk? Just suggesting early :P
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Gazorgan,
    First suggestion already in place. Any mpg in the SVCD sequence-items is delt with.
    Second suggestion - not likley: lots of effort for minimal benefit, IMHO.
    Anyway lets see...
  8. Sounds fantastic please let me know when ready! or if need tester!
  9. Hmmm....sounds great !!!
    I have a lot of SVCD i'd like to put on dvd.
  10. yeah - sounds like a great tool
    if you have if for public-test - plz email me - i wanna test it!!!
    mfi_rules
  11. any nearer to a beta release yet m8?
    Cheers
    KYUSS
  12. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Code is ready but i need to get permission to distrubute some of the external programs..... In particular i need to wait FIVE days before i can post on doom9 in order to contact the author of BeSweet.
  13. oh please oh please make this program happen
  14. i have besweet anyways m8
    fire it over if u want.
    could u make a list of the programs used?
    cheers
  15. I'm a MEGA Super Moderator Baldrick's Avatar
    Finish the tool so I can update and simplify my svcddvdr guide.
    How exactly does it work? Reencodes the audio to 48khz and changes the svcd heaeders to dvd with basicly one click right or?
  16. just checked my email m8...........woo hoo its arrived!!!!!
    Installation:
    installation took a while....for such a small proggy (although pinnacle instantcopy was running in background)
    loaded up the html page on completion.
    everything looks good so far...
    not tried it yet......need to drop some .bin files onto my hard drive.
    i'll get back to you later today m8 with full review
    will it be possible to input mpegs not bin files into it in the future m8?
    Cheers
    KYUSS
  17. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Install is very quick... i suspect it was your background apps. Yes going from mpg & not .bin is planned (as indicated). The app does exactly what i want at the moment. Additional functionality will be for you guys....
    Just found another bug myself. Right click folders must be done from the lhs folder list in explorer - not the right hand side. Otherwise app things its working directory is one up that the real one.
  18. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Just a reminder...
  19. just read html page fully
    sorry for dumb question :P
    instantcopy has an hour to go..........then its full steam ahead
  20. its nor working for me m8
    i dumped a load of .bin files on my hard drive.......right clicked on my computer...........found the folder (in the left pane) right clicked on that....clicked on Svcd2dvd and the proggy opened up...........clicked on start....and after about a milisecond it said it had finished!!!!!!
    tried a number of different .bins and still the same result???
    any ideas m8?
  21. lo again,
    it was all my fault!!!
    i ripped the images to my hard driveusing clonecd...this never produced proper .BIN files.
    when directed to use alcohol120%(thanks chrissyboy) to rip images to hard drive in cdrwin mode it worked first time no probs.
    all steps carried out and completed............
    the only problem i am having now is getting maestro to accept the video???
    it accepts the audio ok.....but video comes up with this error message.........."Media Detection Error (0xc10b001)"
    the file is and mpv file should this be m2v or m1v?
    if so how do i change it?
    i tried just renaming it but it don't seam to work???
    LMK m8
    cheers
  22. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What do you get if you run mpgtx on the file? Should be something like:
    I:\TestArea\small\TESTSV~1.MPV
      Mpeg 2 Video File
      Estimated Duration: 04.00s
      Aspect ratio 4/3 (TV)
      Not interlaced, chroma format: 4:2:0
      Video Format: NTSC
      Display Size [480 x 480]
      Size [352 x 480]     29.97 fps    2.45 Mbps
    from command line:
    >"path to SVCD2DVDMPG\mpgtx.exe" -i "path to mpv file"
    Key things: Mpeg 2, Size [352 x 480]
    In maestro:
  23. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    The other thing that may have happened is that you opted for a PS MPEG. You would still produce a elementry video stream *.mpv, but bear in mind that header patching is the last step. This means that if you choose PS, the *.mpg file will have 352 * 480 resolution yet the intermediate *.mpv file will still be 480 * 480 - non compliant. If you are going to use elementry streams, choose that option & then the *.mpv file will be patched to 352 * 480.
    Spruce DVDMaestro will not use 480 * 480 *.mpv files or 352*480 *.mpg - only 352*480 *.mpv files.......
    Just a thought
    CB
  24. could this application fix a problem with CVDs where the original did not have GOP's closed?
  25. i did it again last night m8 to make sure i selected ES....and i did and maestro still won't accept it????
    getting that Media detection error again.
    any ideas?
  26. Hi m8
    I can't get my player to play the normal svcd to dvdr conversions. Can you mail me your proggy so I can try it.
    I had a look at the guide you have written but I can't find a link to the software.
    DonnieH
  27. still getting media detection errors m8
    how do i copy and paste what mpgtx says...after i right click mpv and select info?
    it says weird stuff!!!
    about not having a header???
    but i've ried 2 completely different films and get same error on both??
    gonna try another tomorrow m8
    i'll let u know.......this time one i ripped myself!
  28. sussed!!!! (well copy and paste anyways)
    MPV
    Skipped -2 zeroes at start of file
    mpgtx: AT EOF - please stop me!
    mmm, this file does not start with a pack, offset: -2
    use the desperate_mode switch as the first option -X to search for a header in t
    he whole file!
    if you want to force the operation. May yield to an endless loop if no valid hea
    der is found!
    Does not even begin with a 00 00 01 xx sequence!
    D:\cd4\ADAPT2~1.MPV is not a valid mpeg file
    Press any key to continue . . .
    MPV
    he whole file!
    der is found!
    D:\cd4\RULES1~1.MPV is not a valid mpeg file
    MPEG
    warning: couldn't find any valid system header. I'm continuing anyway
    D:\cd4\RULES1~1.MPG
    Mpeg 2 Program Stream File [Video/Audio]
    Muxrate : 3.16 Mbps
    Estimated Duration: 05:05:57.73s
    Size [480 x 480] 29.97 fps 2.45 Mbps
    Audio : Mpeg 1 layer 2
    224 kbps 44100 Hz
    Stereo, No emphasis
    whats going on???????????????
    help!!!!!!!!!!!!!!!!!!!!
    cheers
    KYUSS
  29. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I think you source mpgs are shagged:
    D:\cd4\RULES1~1.MPG
    Muxrate : 3.16 Mbps
    224 kbps 44100 Hz
    Stereo, No emphasis
    when you tried with a pukka SVCD image (from me) it was ok.
    Why don't you try to deal with that mpg manually & see what mpgtx/Maestro gives you.....
