Does anyone have any idea or have an easy way to take a series dvd and burn them to a DVDr? I have read all the forum posts and got a lot of help from many people, but most of them are confusing and a bit long. Is there any way to do this simple and easy?![]()
It's not hard. The Soprano's are DVD9's.
The conventional guide doesn't help, because you get 1 episode split on 2 disks.
Use DVDDecryptor and rip individual episodes. They average 55 minutes. Simply Re-Author at 2 eps/DVDR or re-encode and go for 3 eps/DVDR. Re-encoding to SVCD looks okay, they are a bit long for 1 CDR. However, XSVCD looks awesome, lots of still backgrounds in some places.
Soooo, re-encoding won't really lose quality. But 2 eps/DVDR would be a lot quicker.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
DVDXCOPY will do the job. It will put 2 episodes on each disk. Since they are already jamming the disk with 4+ hours of film re-encoding it will make it worse than it is.
Only problem is some of the Soprano disks DON'T have 4 episodes on them. Those you will have to do the old fashion way unless you want to waste a disk on one episode.Don't give in to DVD2ONE, that leads to the dark side. -
I just did some Six Feet Under discs, same thing, but here are two ways.
1. use this guide, it works fine
https://www.videohelp.com/forum/userguides/146795.php
or
2. DVD Decryptor - rip out the main movie files
DVD2AVI - Open the VOBs you ripped out and save the project
- This will give you .d2v and a .wav file
Open these in TMPGE, then in the 'source range' just find the beginning and end of each episode and create a mpeg-2 file for each episode and burn them however you like.
That is the long way to do it, and I didn't get as good of results either.
Put 4 Sopranos episodes from 2 DVD5 to 1 DVD9
By audax in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2012, 02:23 -
Student needs help adding subtitles to Sopranos without converting
By Dains11 in forum SubtitleReplies: 12Last Post: 28th Aug 2009, 10:15 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 11:34 -
Looking for guide: TV Episodes to DVD!
By munchgrunch in forum Video ConversionReplies: 3Last Post: 16th Jul 2008, 00:19 -
DVD Author Guide
By brvignesh in forum Authoring (DVD)Replies: 1Last Post: 11th Dec 2007, 09:39
