i'm really trying to find out if any body has had any success in using the header trick with toshiba brand dvd player or any other brands.
Do not use the header trick. Encode to SVCD and burn VCD using NERO with VCD standard compliancy turned OFF. This works.
I've used it for all the SVCD's I've made. It works every time with my Panasonic RV56.
Lannie
PS Using IuVCR to capture, VirtualDub for fulters and resizing, VCDEasy to burn. (Nero ASPI) -
I have a toshiba sd-3750 and the header trick works just fine. My player will also play it if I just burn the mpeg2 as a vcd
but isn't that more time consuming-ya know we always looking for short cuts.i guess i'm really trying to see if the trick has worked on toshiba's.
hey Treebeard
how did you do the trick with TMPGEnc-like what where the steps that
you used in order to make it work.if you wouldn't posting me the settings
that you used. -
I've been using the header trick for awhile with no problems. I have a sony dvd player.
I have a toshiba sdk615 five disc dvd player and I have tried several headers and burning methods and my end result was i can not play a svcd using the header trick nor can I play a svcd as a svcd
don't hang your dirty laundry in public
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
Any success with cbreak?
By orev in forum EditingReplies: 2Last Post: 21st Nov 2007, 13:01
