I made a SVCD with chapters. I used VCDEasy.
When playing back, I observe:
- Access to chapters via numeric keys: OK
- Access to previous chapter with "previous" key: OK
- Access to next chapter with "next" key: does not work!!!!
What could be the source of the problem?
I can provide a copy of the xml file if someone would like to check.
Thanks!
Results 1 to 12 of 12
Hello Jürgen,
YES I have a Cyberhome 505!
Do you mean that adding a second MPEG sequence (even so small as a fraction of a second) on the SVCD will solve the problem (navigating though chapter on the first main sequence)?.
In my 505, the firmware is still 668; do you think that an upgrade to firmware 669 would remove the bug?
Thank you
Michel
Not sure about regards the firmware, or whether the bug will completely go away with the additional track (though it probably will-burn 1 and see), but remember that an additional MPEG sequence is laid out as a TRACK. Tracks have the requirement that they be a minimum of 4 seconds. Other than that, burn away...
Hello Michel
yes I meant to add a second MPEG file as normal sequence track. But as Scott mentioned this MPEG file must be at least 4s long. Otherwise you will violate the VCD standard.
I am already using the latest firmware 669 and it does still have this bug. A new firmware is now expected since months where it is said that this bug is fixed. The latest forecast is a new firmware release within the next two weeks but this was said several times in the past.
Jürgen
Hello Jürgen,
I will try your solution.
By the way, a have made a VCD 2.0 with mpeg stills on it (pictures) and a menu at the beginning, in the form of a video that repeats itself until you press a numeric key that brings you to a set of pictures, etc.
In that case, I suppose I do have multiple sequences on my disc (the menu video sequence + all pictures).
Even with this disc, the "next" key does not work, though it should according to you, isn't it?
Michel
Hello Michel,
yes I had the same problem with picture still CDs as you described. And also here I solved this problem by adding one additional sequence tracks to the already existing track. The menu and all the other pictures are not sequence tracks but segments which does not help to solve this firmware bug.
Jürgen
Jürgen,
Thank you for your answer.
I don't understand the difference between segment and sequence.
I think what I have done is to add segments (menus, still pictures) and not sequences.
Could you tell me how to add sequences on a disc with VCDEasy?
Thank you in advance.
By the way, maybe the brand new FW 20.710 will solve the problem...
Michel
Hello Michel,
sorry for confusing you a little bit with technical details.
In fact if you add still pictures (or menu pictures) to a (S)VCD then these are automatically added as segments. You can see that VCDEasy has an empty box at the beginning of the line with the file-name of the picture.
You are only allowed to add still pictures as segments to the CD and not as sequence track. So you should not change this.
If you add a video-mpeg file then VCDEasy automatically add this file as a sequence track. There the box at the start of the line is checked. In normal circumstances this is the correct adjustment and you need to change this only in exceptional cases.
Now you have to make sure that you have included at least two video-mpeg files as a sequence track (at least to boxes are checked). Then you will see on the display of your DVD-player that you have two tracks on the CD and then the next key is working well.
I hope that the above work-around is really not necessary any more with the new firmware which has been released this week. But I have not tested this firmware until now.
Jürgen
interesting security problem, need some input
By deadrats in forum ComputerReplies: 3Last Post: 23rd Nov 2009, 22:58 -
Interesting Connection Problem. LG DVD Recorder to Samsung LCD TV
By kramsey999 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Oct 2008, 01:13 -
An Interesting Problem
By Randalliser in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 9th Jun 2008, 19:15 -
interesting VEGAS 8 render problem
By compusic in forum EditingReplies: 3Last Post: 8th Mar 2008, 08:11 -
Interesting problem with new Sony titles
By Nilfennasion in forum Newbie / General discussionsReplies: 8Last Post: 25th Aug 2007, 08:01
