I am having problems getting my PC to recoginze my firewire input, and am getting frustrated.
I am working with:
Dell Latitude Laptop with firewire board built into motherboard.
JVC DVF21 video camera (and have also attempted a SONY Handcam).
Windows 2000 (cannot upgrade to XP because my company software will only work on 2000).
I downloaded the lastest DirectX - version 9.0
I have been on the phone with Dell customer support for probably 40 hours over the last 3 weeks, and I have them stumped. I have replaced the motherboard, firewire cable, tried 2 different cameras, and reformatted my hard drive and started from scratch - at Dell's urging - still no relief.
I cannot get any help from JVC.
When I plug the firewire cable into my laptop - absolutely nothing happens. I go to device manager - and the IEEE1394 Bus Host Controller (Texas Instruments) says it is working properly.
Can someone tell me what I might be missing here?.
Thanks for your help in advance.
Rich
Have you tried some other firewire (non-camera) device? Like a harddrive?
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
upgrading to dx9 prob made things worse .. what a load of .....
the dell onboard firewire is known to have tons of problems (as do many onboard firewire solutions)...
just get a pccmia firewire card instead ... i think ads makes one ..
of course .. turn on your camera and plug it in AFTER you have booted up ..
many systems have a problem with multiple devices on your firewire chain ... try w/ only one item ...
try running the camera on battery instead of power supply .. sometimes when running on powersupply there is a small voltage differential between devices (which causes a ground loop on the firewire buss) .. rare , but good way to just rule it out as a problem .. -
BJ_M-
Is there any way to uninstall DX9 without causing a ton of problems? If so, what version, if any should I load?
How do I know what is on my firewire "chain" - Currently the camera is plugged directly into the card?
Running from battery did not work. Next step is to get a PCMIA card.
I have tried (2) different cables from the same manufacturer. Is there a possibility that i do not have a "video ready" cable?
Thanks for your help. -
cant uninstall dx9 very easy ..
dont know what a video ready dv cable is -- i didnt know there was more than one type.
firewire chain = any thing else plugged into firewire?
try also disabling your usb ports in your bios -
if you want to use the firewire port to capture make sure the camera is turned on before starting computer then it will see camera
see this thread here
https://www.videohelp.com/forum/viewtopic.php?t=148185&highlight=
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
Adobe Premiere Pro Not Recognizing Capture Card
By ercdill in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2008, 14:59 -
Philips DPV-5992 not recognizing a USB HD - "Input Invalid"
By benvid in forum Newbie / General discussionsReplies: 6Last Post: 21st Jun 2008, 17:02 -
Sony HDR-FX1 firewire-input-port
By stompinne in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 25th Feb 2008, 14:23 -
My DLP HDTV accepts 1080i through component input, vid quality = HDMI?
By Denvers Dawgs in forum Off topicReplies: 4Last Post: 9th May 2007, 13:16
