HI
I am new to this VCD burning field and have successfully burned a few VCD using Easy CD platinum and have problems playing it in my Panasonic DVD-CV36 (DVD-VCD player). The player is not supporting Menu all the time. It works for the first three choices and than goes all the way to the last sequence. I tried with simple play sequence and it did not work after first three tracks. It worked well on the Easy CD preview though. Any idea what to do to correct this? I tried with a few different video clips and track combination and the same thing happens.
Your help and feedback is appreciated.. thank you.
Results 1 to 1 of 1
Easy way to set DVD to play next file instead of returning to menu?
By Calidore in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2012, 19:04 -
DVD Player doesn't play menu
By nharikrishna in forum DVD & Blu-ray PlayersReplies: 6Last Post: 21st Mar 2011, 06:48 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 15:26 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 15:33
