  1. I'm using DVDx2.1 in order to rip a dvd to SVCD format.
    I've put the bitrate at 2520.
    The problem is that fast moves in the video results in a lot of blocks.
    How do I prevent this blocks in fast videoscenes
    (Do i have to lower the bitrate?)
    trench
  2. no, lowering the biterate will make it worse. my suggestion is try and use tmpenc to encode svcds.. i found that the most successfull other than CCE. you can see how to do it at http://entiendo.gotnet.net/ . tmpgenc has a setting called motion precision that helps with this problem.
    Mar 2002
    United States of America
    Set the Motion search precision to High quality (slow). :P
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...and try VBR with a high max bitrate, like 500 min, 2000 ave, 3500 max(if your player can take it!)
    /Mats
