Hi folks,
how do I tell DVD2SVCD that it has to use special settings to "feed" TmpgEnc? Maybe there's a trick to halt DVD2SVCD so that I can change the TmpgEnc.ini?
Thanx for any suggestions.
Go to the 'Frameserver' settings and enable the option 'Edit as part of Video encoding'.
I gave it a try. But I didn't find the clue. This gives me the option to edit the avisynth-script-file not to edit the tmpgenc-settings.
Can you give me more hints? -
Hi Buffist, sorry for the delay but I have been away for several days - at a place that had no phone, no PC and no Internet - nice change from my usual environment.
As to your question, no there does not appear to be a way to stop DVD2SVCD and alter the TMPGEnc parameters. DVD2SVCD creates a TMPGEnc project file (a .tpr file) but you can't edit this directly. You can change the settings in the DVD2SVCD.ini file that relate to the TMPGEnc settings but this is just the same as setting the values in the gui interface.
What settings in particular are you interested in changing (between the gui parameters and the AVISYNTH filters, most TMPGEnc settings are covered). -
Thanx for your reply. But I found out, that one can change the TmpgEnc settings in DVD2SVCD in some setting tab. There is a tab called "advanced" and there one can change all settings for TmpgEnc that one can do like in TmpgEnc itself.
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
