I have this movie (won't say the name of it here because it's still in theatres, I have paid to see it and I will get the dvd when it comes out and any extended versions after it) that wouldn't play at all until I got an XviD codec. The problem is that now that I have it, there are a couple of times during playback on my media player that it will freeze and crash the media player. It only happens at 2 specific points during the movie. What happens is the sound keeps trailing off, but the picture becomes pixelated and the color goes screwy and then it crashes. If I re-open the file, I can watch it directly AFTER that short point, but that's it. I just want to know if anyone knows from experience why this is happening and if this will become a problem during encoding? I have burned a small sample SVCD that works and everything, but the picture is jittery and the sound is off by maybe half a second, to a second. Does anyone know what the problem might be? I hope I've explained my problem clearly enough, if any more details are needed, I'll provide them. I did try to look this up myself, but I had no luck. I'd appreciate any help. Thanks in advance.
Peace
Rob
you need the Xvid_install file codec but i dont know were you can get it from.
the movie simply has bad frames in it, there are plenty of good guides on how to delete these frames so you can encode the film.
however I downloaded an xvid codec called alpha from Kazaa that plows through bad frames in films, you might want to search this out.. -
I have the same problem.
Virtualdub & any other program freeze & get an error in some specific part of Episode 2 2nd CD, it's always the exact same part. Is it supposed to be just a bad frame?, how can I "JUMP" that frame? -
i have the same problem, when i play or convert some Xvid movies some time into the films they start to freeze but the sound keeps rolling on, i've downloading alpha codec as mentioned before, but it doesnt help, what do i need to get it working?
why i man. i just got the problem sorted
go 2: http://www.moviecodec.com/mb/topic.php?tid=867
and the 2nd post tells all, even though the guy jibbers on for a bit. the answer to all our problems, the holy grail!!!!!!!!!
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
Windows media player freezes at each chapter
By stem300 in forum Software PlayingReplies: 2Last Post: 23rd Jan 2012, 22:37 -
Media Player Classic + M2TS embedded subtitles on Win 7 freezes video
By Polaris75 in forum SubtitleReplies: 0Last Post: 14th Mar 2010, 12:28 -
Need advice on divx/xvid media player file query??????
By Humbug in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2008, 18:39 -
VIBE EN306TV-S Media Player has problems with Xvid file playback.
By Timfoxx in forum Media Center PC / MediaCentersReplies: 1Last Post: 6th Aug 2007, 21:34
