    Feb 2003
    St. Louis, MO
    In an attempt to backup up a DVD, I ripped a DVD-9 using DVD Decrypter and then used Instant Copy 7 Demo to convert it to a DVD-5 to my HD. This part worked great and the ability to remove audio tracks/subtitles and reduce the size of extras is awesome. But then I tried to use Instant Copy to burn it out onto a DVD+RW using my Sony DRX-500UL and it errored out both times.
    Has anybody else had this problem?
    The fix was to use pdi2iso, then used DVD Decrypter to write out to DVD-RW. This worked and the finished product was incredible. I used my wife's Sweet Home Alabama and she could not tell the difference. I would say total time was between 2 and 3 hours.
    Great product, does anybody know where I can purchase it in the US?
  2. I burned straight to dru500ax with IC7 and had zero problem. I burned with the sony dvd+rw that came with it.
