Hi,
Trying to do Band of Bothers DVD's. Each title is about an hour which should cover 1 DVD each, however Each episode is going onto 2 DVD's. The main DVD is a DVD-9 and is only 6.98GB.
OSex is showing title 1 to be 2.96GB and title 2 the balance, however on the first title to be put onto discoplus, it is top[ing out close to 6GB.
Am I missing something or is this the way it goes. Jut wondering, thanks for any replies,
Rob
Yep, this is happening to me as well with, OZ DVD's the 1 hour episode is being split into 2 DVD-Rs. The work around for me is to use DiscomVOBulator not the + version. With Disco the Episodes all fit onto one DVD, also you can choose the audio you want, not have 6 audios you will never need on the DVD. Hope this Helps.
Mactrav -
Went back and used regular disco and problem solved. 1 episode per DVD. Worked great.
Thanks.
OT - any DJ here can help to ID these Gym/disco MP3?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 20th Nov 2010, 23:42
