I have an IEE1394 used for capturing from a SONY digital Camera. I have never had problems with capture. Using VEGAS video and video factory. NO problem.
All of a sudden, after filming a wedding and trying to capture the video, I get clicks, drop outs (no dropped frame though) and then it goes into TOTAL stutter mode.
Help !!! I have tried the following:
Update Drivers
Rolled back my system (via a clone drive) to over a week ago when I know all was working
Reseated all cards
The only thing I can think of is my FIREWIRE has gone bad....Dont think/not sure it is software.
It will capture fine for a moment or even for 5 to 10 minutes. Then I will hit something that makes it STUTTER like.
This is viewing also, not just capture so it is not a hard drive. And playing on the camcorder it looks great.
The only other thing new is a newer faster P4 (2.4 533 mhz).
So , how do I test the firewire short of just buying another one ?
I have ruled out hard drive, Vegas software and drivers.
PLEASE HELP. This is my business and before this occurance, capture was a breeze
Just a couple of suggestions. Have you tried the firewire out on another computer? OR download a capture program called DVIO ( look for it in "tools" under "capture". It's very simple and if that doesn't work it must be a firewire problem. Best of luck.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Well, tried the DVIO and sure as heck, same issue on that part of the tape. It comes and goes. But as I said it is not the tape. The tape plays BEAUTIFUL on that camcorder and I have another, Hitachi, plays there too. But the both are having the same result on capture.
So you think thats pretty indicative of the firewire gone bad ? Is that common ? I mean it was a cheap card (15 dollars) so maybe I need to go ADS or Belkin ? Any recommends ? This one had a TI chip uggg.
I dont want to get a card and have the same or NEW issues.
Again my thanks and suggestions welcome. -
Okay, bought a new FIREWIRE today (Belkin) and will test tonight. I am however. wondering if it is an IRQ issue. I recently updated motherboard BIOS. WHen I checked yesterday, IRQ for firewire was shared with Video card. Not good.
I move dthe card, etc..and it went to the PCI bus controller..Not good either.
How am I going to force this thing to its own.......
Sigh...
SLP has gone bonkers but SP fine on VHS/DVD PLAYER.
By spicy83 in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 00:13 -
Avast Free Home Goes Bonkers!!!!
By hech54 in forum ComputerReplies: 29Last Post: 7th Dec 2009, 13:32
