i have loads of MPEG films ive downloaded how would i put them onto dvd format so i can play them in a normal dvd player.
im using nero and 4.70gb discs
check the menu bar to the left, read through the "Newbie", "Convert" and "Author" sections. The guides there are incredibly informative and give you step-by-step examples.
then check the "Tools" section for the tools you'll need... TMPEGenc will be one of them.
- housepig
Encode MPEG-4 to DVD Format Without Doubling File Size
By JustAnotherUsername in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2012, 22:10 -
Which format produces better quality overall MPEG-2, MPEG-4 or .x264?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2009, 03:00 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
I've got an animation I did in MPEG format and I want to burn it to a DVD
By el_cid in forum Newbie / General discussionsReplies: 6Last Post: 3rd May 2008, 14:11 -
MPEG Transport Stream Format
By Hoggle in forum ProgrammingReplies: 3Last Post: 26th May 2007, 20:03
