i have an avermedia studio capture card..
for the most part it seems to be a nice card, it says it captures in
mpg 2 format but nero wont take the file as a svcd file, says its not the right format
i am not sure what to do about that...
also, what can i use to edit out commercials of programs i capture...
would like to capture episodes and edit out commercials etc and put several episodes on a dvd with sonic dvd which came with my burner..
anyway, thanks for the help
Run it through TMPG ENC. to end up as a svcd. You can edit out adverts in TMPG if you go to "merge and cut" in File/mpeg tools. You will end up with severall clips which you merge later (in same program)
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 18:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
