how can i enable DMA in windows xp pro.....thanks
Right click on the 'My Computer' icon.
Select Properties.
Select the 'Hardware' tab.
Select 'Device Manager'.
Click on 'IDE controllers'.
Right-click on 'Primary IDE' and select properties.
In the 'Advanced Settings' section the transfer mode for each device should be set to 'DMA if possible'.
Do the same for 'Secondary IDE'.
If they are set to PIO and you change them to DMA you will need to reboot. -
If you don'r see the advanced settings icon you'll have to remove Intel Application Accelerator which is commonly installed on machines
Panasonic DMR-ES45VS, keep those discs a burnin'
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 14:45 -
Weird Doings in PIO - DMA-ville
By Seeker47 in forum ComputerReplies: 13Last Post: 28th Nov 2008, 13:15 -
DMA PIO Reg Prob Key Deleted returns after reboot
By tonib95 in forum ComputerReplies: 14Last Post: 4th Feb 2008, 10:23 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 22:35
