Hi!
I have my new BT8x8 card, I installed the BtWincap drivers, I installed my Creative SoundBlaster Live drivers, I installed VirtualDub and the Huffyuv codec.
So I started capturing video, but I cannot choose 48 KHz audio frequency. The highest I can choose is 44.1KHz.
Anybody can help?
Since I'd like to store my videos on DVD, if I cannot set 48KHz audio, I have to upsample the audio to 48KHz of every captured file.
Thanks for any help.
Bye,
Massi.
Results 1 to 12 of 12
I had exactly the same problem whn trying to capure in Windows 98. I had to upgrade to Windows ME or Windows XP for this to work.
Any number of OTHER programs allow 48kHz: Video Studio, MMC 7.7 (ATI's own software), etc. You can then import that AVI into VDub for further processing...
When I was using win98 I couldn't get ANY program to use 48khz - the option just wasn't there.
Unfortunately, TMPGEnc messes up audio when re-encoding, producing a VERY bad audio on the re-encoded file...Originally Posted by Fozzee
Problem is, when I used the motherboard built-in audio chip, I could capture with VDub at 48KHz with no problem.Originally Posted by oldfart13
Now I have a SB Live, that should be more powerful than the MB built-in audio card, but it doesn't let me capture at 48KHz. Seems like SB drivers don't let you do that... -
Originally Posted by superfresko
I have 6 recoded DVDs which say different , there is a guide to using ssrc instead of tmpgencs own if yours is not working , but mine definitely is - all in sync and no apparent degradation either , are you using the HiQ / Slower setting ?
But if you replay the converted 48khz file back through media player it does sound knackered (full of crackles and pops) which is probably the case . I replay mine through PowerDVD and they sound fine and obviously when I play them on my dvd as well .
vdub - bad PCM audio capture after fresh install of huffyuv
By wolfdogg in forum Video ConversionReplies: 1Last Post: 11th May 2011, 01:45 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
Capturing with VDub sometimes doesn't capture audio
By CursedLemon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Feb 2010, 21:50 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
Nero Recode and 44.1kHz audio
By rindless in forum Portable VideoReplies: 2Last Post: 6th May 2007, 15:16
