Im trying to rip a dvd. It is 4.30 gigs. I got this error message on both smart ripper and dvd decrypter. The error message is
" backup file VTS_01_0.bup should be identical to "VTS _01_0.ifo. dvd compliance test failed.
The whole dvd rips and plays fine. it just wont burn
Any suggestions?
What happens if you just copy the IFO file and rename it BUP ?
If that works then don't worry about it, although it would be nice to know where the difference came from. -
I had that same problem last night. The way that I got around it was, even though the movie is 4.3GB, run it through DVD2ONE and then burn to DVD. There is really no video quality lost. After I did that I had no problems.
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 11:40 -
Nero - Compliance test failed? whats up w/ this?
By BRYAN_B28 in forum Authoring (DVD)Replies: 11Last Post: 2nd May 2012, 01:13 -
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 07:14 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
