I've found various ways to clean up an avi file with filters like those in VDub but after I convert the file to an mpeg file with TMPEG, there are some artifacts and I'd like some advice on how to minimize or remove them. Can anyone advise me on how to do this and what programs to use? Thanks all.
If you are happy with the tools you have found for AVI, then convert the MPEG-2 file into AVI and use those.
The simplest way I would recommend for this conversion would be the MPEG-2 enabled VirtualDUB. Open the MPEG-2 file, select the output compression codec and save the AVI.The more I learn, the more I come to realize how little it is I know. -
Perhaps I should have mentioned I'm refering to mpeg 1 type files. When I capture, I can clean up the artifacts that are on the compressed avi but once I convert to mpeg 1, there are some artifacts that I would still like to clean up. Thanks.
Encoding in MPEG-1 creates artifacts (square blocks visible while the film has increased action or motion or panning).
These are inherent results of the compression. If the MPEG-1 encoding is for VCD (1150kbps) then there is almost nothing you can do to remove them.
Encoding in VBR with min bitrate at 200, max at 1200 and avg at 1150 may help a bit.The more I learn, the more I come to realize how little it is I know.
Avidemux - How to clear recent files
By ccm58 in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2010, 02:25 -
Blocking Artifacts in MPEG-4 AVC / H.264 Video
By Eva-Unit01 in forum Video ConversionReplies: 0Last Post: 28th Aug 2010, 14:36 -
WMV vs. MPEG compression artifacts?
By smexxy in forum Video ConversionReplies: 5Last Post: 16th May 2009, 23:33 -
artifacts while playing xvid files
By greendesert in forum Software PlayingReplies: 2Last Post: 3rd Jan 2008, 11:42 -
programm for joining mpeg2 files without decoding and artifacts
By mb508 in forum EditingReplies: 1Last Post: 7th Aug 2007, 06:51
