  1. Hello,
    I use dvd2svcd to burn all my .avi files to disc. If your familiar with dvd2svcd then know you can pick how many 800 mb cd's you want to burn on. My prob is that when i choose 2 cd's on any 1hr 40 min long flick sometimes i'll get 3 .bin files where the last one has about 3 min of movie and the credits. Is there any way to fix that when it doesn't happen. Or is there a way to merge and cut a bin file???
  2. In the bitrate tab, change the amount you want to fit on each CD. Instead of 50 min., make it 60 min. on each CD.
    PlaiBoi
  3. Hi,
    Well I've tried changing the bit rate from 0 to 50 to 0 to 60 or even 70 and it doesnt' seem to help. I always get 3 cds when I put 2 with one having about 10 seconds of movie then going to the credits. I know there is a way to change the bitrate where you can fit more movie on a cd. It seems I can only fit about 46min of a movie on to 1 cd. I don't know how to get that 10 lousy seconds on the 2nd cd. Am I using dvd2svcd wrong? In assuming when the movie is 100 min long that if you put from 100 to whatever use 2 cds at 800 mb each that it should do it. But it is weird. Both .bin files have 800 mb with a 3rd one with about 70 mb. Any thoughts?
    THX,
    Wackyd
