I have been usin both IC7 and Dvd2one successfully for about a month now- Every1 plays perfect on my ps2. I use Smartripper, then either IC7 or Dvd2one and burn with Prassi dvd to ritek G03 silvertop in a 104 with 1.31 firm.
My problem is how can i copy one of these copies??
I've tried everything from Nero's Copy Dvd option(which gives a read error), to rippin with Smartripper and tryin to burn back with prassi(another error reading VIDEO_TS folder). I've tried the recommended dvdrhelp way usin dvddecreptor but the image it creates is unreadable by it and nero and prassi.
Can some1 please tell me what im doin wrong and point me in the rite dirn?? Thanks a mill in advance
Results 1 to 11 of 11
use dvdecrypter rip to iso and burn the ripped .iso with dvddecrypter..can't get much simpler than that.
https://www.videohelp.com/forum/userguides/141024.php#dvd5 -
Dvd decrytpter
Iso read ( make image )
Iso write ( write image to disk ) -
Thanks for da prompt reply lads but ive tried these methods and got nothin but coasters!!
I just used dvdxcopy to copy a copy successfully so all is kinda well. -
well if decryptor dosnt work then what i haev done before is ripped the whole burned dvd and then used nero just to reburn it and worked great
Justin
:agree: -
I don't see why you guys could'nt just use the DVD copy thingy in nero.Since a copy has no encryption junk,it should be able to copy the copy properly.
I'd try it myself,but i'm low on DVD-Rs and don't have any to spare to test it out. -
Since there is no CSS on the disk (because it is a copy) why can't you just drag and drop the contents of the disk to your HDD with explorer ?
Then you can re-burn the contents with Prassi. -
I have done a about 6 dvd copies using Nero.
You get a read error warning that the movie may not play back properly.
Just pree yes to continue.
I did however have my first failure tonight. Re-tried on a -rw and worked okay.
Try it first on a - / + rw.
dlb. -
Unless I'm an idiot the most simple process is copying the VIDEO_TS folder back to your hard drive and making another dvdr like that.
I can't copy disk to disk and copying back to the hdd first is faster than creating an image file.
Works for me everytime.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Originally Posted by joc_06
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I have tried to copy my Conan dvd (created with instant copy) with nero but my dvd player not read anything...I have tried with instantcopy and my player read...I think nero and other programs have problem with some dvd player, instantcopy have some optimization for compatibility on his writer engine.Anyone know a system or a software to analyse the copy created with instant copy for view how this program forces the compatibility?Nero have a "force dvd video compatibility (for x-box)" check on writing properties...Is this the solution?I remember i cannot create my own dvd video with Sonic my dvd (or other software authoring)for the same problem: my home dvd player not read! The only software working for my dvd home player is Instant copy!
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31
