  1. Hi there,
    I tried to make a picture slideshow with my mac using the guide on this site (https://www.videohelp.com/VCDmacslideshow.htm). Since I wanted to check out the easy way first, I used the low-quality method: I converted my pictures with GraphicConverter, then dropped the .moov files in the vcd Window of my Toast Titanium 5.1.2. But I got a message, which I will translate for you since I use the german Toast Version:
    "1.moov could not be used for the making of video CDs because the files does not contain any audio data or because the audio data could not be exported"
    Here's the original version if any of you is capable of german:
    "1.moov kann nicht zur Erstellung von Video CDs beutzt werden, weil die Datei keine Audio Daten enthält oder die Audio Daten nicht exportiert werden können."
    Well, what can I do now? Any kind of help would be nice. Thanks a lot.
  2. You'll have much better results with VCDbuilder. Check it out here:
    http://homepage.mac.com/johan/
