Just wanted to post this somewhere.
Having read success and failure stories with connecting two XP computers together with firewire we thought we'd give it a go.
Two weeks later its works.
We first bought two cheap Dlink cards - DRF-A3 (also called 500 something in the US AFAIK)
We also bought a 3m 6pin to 6pin lead.
Did it work... nah... got nothing at all.
Then tried a belikn firepath cable. That at least gets an IP, but doesn't want to go any further.
Tried hooking a DRF-A3 to our Sony Vaio with supplied 4pin to 6 pin cable. It works or so I thought, but proves unreliable (SP1 XP solves firewire issue).
Had enough of Dlink card - read up to find its only based on 1995 standards. So we buy lucent cards instead - just as cheap only to try avoid spending a fortune on adaptec or whatever.
Guess what? it now works. Its sounds like an easy solution but I've been pulling my hair out over this for two weeks. THAT I MUST GET IT TO WORK.
So rules of thumb for this - If you want network firewire - NOT ALL CARDS AND CABLES ARE THE SAME. DONT BOTHER WITH DLINK (Unless they have an updated card).
Looked everywhere for someone to say this - and couldn't find it. So here it is.
So now have 400 Mbps networka bit cheaper than a Gigabit! (of course it will cost you less if you don't do all the fafin about we did
Hi there
No I don't think so the new lucent card works fine when connected to the vaio - its the dlink card that was the problem
Regards
Windows 7 (x64) and Set Tob Box Firewire (1394) capture?
By techiejustin in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jun 2011, 21:57 -
DV to PC -- Firewire Problems; 1394 vs. USB; Capture Software
By GrayStrickland in forum Capturing and VCRReplies: 1Last Post: 27th Apr 2010, 12:27 -
No Firewire/1394 on newer laptops ?
By Movie-Maker in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2009, 18:01 -
DVD player with Firewire (1394) out
By PizzaPete in forum Capturing and VCRReplies: 9Last Post: 23rd Oct 2008, 01:05 -
Questions about DV transfer and connectivity of Firewire/1394
By Movie-Maker in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 14:46
