howdy all- i've been having problems with vcd. some vcd's that i burn play just fine in my dvd player. however, on some vcd's, the tv screen rolls over and over. i'm not burning them any differently. they are downloaded files so i can't tell what kind of encoding they are (pal or ntsc). the movies play fine on my computer, and i'm wasting lots of discs just to find out i cant' watch them on my dvd. can anyone help? thanks- mike
They are in PAL or NTSC. I have a NTSC television, so PAL doesn't work for me (rolling screen). I believe you can change between NTSC/PAL with some players and it converts the signal on-the-fly to the tv.
Tom Green Sucks! -
search for a software called bitrate viewer. that will tell you in much detail the aspects of the file(s). You could try http://www.divx-digest.com - I *believe* I gotmy copy there. If you are stuck, I will email it to you.
sorry, i should mention that this software works for all mpeg1, mpeg2 based files
Rolling Shutter and Deshaking
By blewyn in forum EditingReplies: 8Last Post: 5th Feb 2012, 15:45 -
Burned DVD plays back with rolling / flipping screen
By thedaylights in forum Authoring (DVD)Replies: 3Last Post: 4th Nov 2009, 14:14 -
rolling/jumping with VHSc
By highaim in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2009, 21:03 -
Tools for Rolling Credits
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 28th Apr 2008, 15:53 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35
