Giday, I dont no if this is the right forum, but I need to know how do I change the muxer rate for a mpeg file. I use WinOnCd to burn cd's.
Cheers scott
Results 1 to 16 of 16
you have to understand I am a real dumbass when it comes to computers and what you asked me, I didnt understand sorry! The error message I get with some mpeg files is "...has an invalid muxer rate (3484) and is not suitable for video cd". Someone told me that I need to change the muxer rate to arrr.. 1.5 I think it was. And I cant find the options where I can change it. Thats all! please help
What program do you use to multiplex your files???Originally Posted by scottee20
You should try using bbMPEG as its the best MPEG multiplexer out there!
:P
Here's a link to where you can download bbMPEG:
http://www.divx-digest.com/software/avi2mpg2.html
Hope That Helps!!!
:P
yeah I did download that, but my files are already mpeg files. i just need to know how to change the muxer rate please
sorry, but "v been telling you wrong. What I need to change is the Video Bit rate, this is what I was told to do "...This message is due to the incorrect video bit rate. All burning software when burn a movie to VCD format require a movie having a video bit rate of 1.15 Mbps. To resolve this problem set the video bit rate in the setup dialog box to 1.15 Mbps before start recording."
So, any help!!?? -
You could've created a XVCD.Originally Posted by scottee20
XVCD:
XVCD stands for extended VCD. XVCD has the same features as VCD but is possible to use higher bitrates to get higher video quality. XVCD is basicly everything that uses MPEG1 video, except it is not within the VCD standard and burnt in "VCD"-Mode.
Hope That Helps!!!
:P
If your mpg is encoded with a non-standard bitrate, then the only way to fix it is to re-encode it. You can do this with TMPGenc which is in the tools section to your left. The easiest way to do this would be to first close the stupid wizard thing that pops up...then load your mpg as both the video and audio source. Then click load and load either the NTSC or PAL VCD template and hit start. If you live in the US, CAN, or JAP than you need to use NTSC, most other places use PAL.
As puertorican138 suggested, many dvd players are actually quite leniant with non-standard VCDs (XVCDs) depending on how non-standard they are. If your bitrate is not much higher than 1.15Mbps than you might want to just try burning to cdr/w to see if it works on your dvd player. Of course, when making non-standard disks there is no guarantee that it will work on any other dvd player, including the next one that you buy down the line. -
puertorican138 can you please not post every sentence in a different post? It makes the thread very difficult to read and unnecessarily wastes bandwidth. If you have something else to add then just edit your previous post.
Changing audio frame rate?
By architectofpain in forum AudioReplies: 22Last Post: 5th Apr 2013, 11:27 -
Changing DVD Frame rate
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 28th Dec 2011, 20:58 -
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 03:32 -
how do i know if Nero is changing my audio bit rate?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 19th Nov 2008, 16:49 -
changing frame rate, making a better dvd picture
By motleycool in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2007, 03:30
